I tried to flash this morning and I had a FAILED on Preparing VCM. Then I had all kinds of error messages...Reduced power, service traction control, low fuel and maybe some others. I ended up doing a Non-active write test and it cleared all the errors. However, I did end up with a U1000 code that I was able to clear. The problem is that the stereo is dead. Not even a Clock. 2003 Z06, Factory Stereo.
Thanks in advance for any help.
Update. At lunch I did a write entire and still no radio. I've also removed the PCM fuse a and b for about a minute. I will try disconnecting the battery for 5 min when I get home.
Any other ideas.
