Page 1 of 5 12345 LastLast
Results 1 to 20 of 81
Thread: Tuning LTFT's...
    Apr 2007
    40
    Tuning LTFT's...
    whats the easiest way? im running real rich and i wanna get it close to 0. ive looked but my car its lb's/min and everything else is g/sec.
    thanks!
    btw its for a grand prix
    99 GTP....Mods, yea i got a few
    Aug 2007
    48
    Sorry I don't have the answer, and I was getting ready to ask the same question, but I do have a question for you.
    How are you monitoring your injectors? I wanted to monitor the duty cycle to see if I'm beginning to max them out out or not but if I can see what lb/hr they are doing I can live with that. What sensor and/or PIDS you using? Do you have a gauge set up for it?
    Apr 2007
    40
    no 1 here has tuned their fuel trims? wow
    Nov 2005
    Houston, TX
    3,968
    Tried reading any of the stickies? Whats the easiest way to tune my LTFTs is a rather general question. We're not here to spoon feed you, asking specific questions is more helpful.
    Bill Winters
    Out of the LSx tuning game
    Apr 2007
    40
    yes ive read. i was wondering if there was an easier way than using the fuel trim tables and my maf numbers.
    "In the scanner under Table it will have a bunch of different things listed, find out what your Mass Air Flow is at idle (lb/min.). In the editor go to Airflow->General Airflow->Airflow vs. Frequency. Find the cell closest to your value, select it and a few around it (about 4 on each side) and multiply them by a small amount, since you want MORE fuel, say 1.05 (I explain what I did to subtract fuel later, but it's probably obvious ). Then select a few frames further on both sides of what is already selected (for a total of about 6-7 on each side) and click the little green button right above the 2000 that says "smooth selection" when you scroll over it. Then write the tune to your VCM and repeat the process, let the car idle for a few minutes and see what the LFTF's are. When you get them closer to 0 you can go in smaller increments, say multiplying by 1.03. When you get them around -2 to 0 you are in good shape. "
    thats what i was sent
    Nov 2005
    Houston, TX
    3,968
    OK, there are indeed easier ways to do it. I've never tuned a V6 so I hope everything I say applies but it may not.
    You need to make the histograms work for you. Set up a histogram that plots LTFTs against the MAF table. Just drive around, trying not to enter PE because when you enter PE fuel trims lock out so any data in PE is no good. You are only able to tune part throttle with LTFTs. Post a tune and a log and I can help you with the histogram. Once you have the histogram all you need to do is take the data you collected and copy and paste it (paste special, multiply by %) into the actual MAF table. Reset your fuel trims and repeat, the fuel trims should be closer now.
    Post a log and a tune and we can make some real headway.
    Bill Winters
    Apr 2007
    40
    ok sweet. i gotta install my ported TB tomorrow and then ill get some scans..
    thanks!
    what do you want me to scan for?
    Nov 2005
    Houston, TX
    3,968
    Just do a quick scan, all I want to see is what PIDs you are logging and are capable of logging.
    Bill Winters
    Apr 2007
    40
    this is usualy what i scan for:
    engine RPM
    Vehicle Speed
    Throttle Pos.
    Ign Timing Advance
    Knock
    Mass air Flow
    Manifold Pressure
    Engine coolant
    intake temps
    delivered trans torque
    current gear
    O2 voltage
    injector pulse width
    total missfires and what cylinders
    Long term Fuel trim
    Air fuel ratio command
    thats what i have set up to scan for..someone mentioned having to scan for something different instead of the MAF to get the histogram to work right?
    Nov 2005
    Houston, TX
    3,968
    Depends on which MAF PID you mean. You need to be logging MAF Hz not MAF g/s in order for the histo to work.
    Bill Winters
    Apr 2007
    40
    ok i can scan for that..ill do a scan in a little bit. still waiting on my gasket for my TB
    Apr 2007
    40
    you got a PM
    Apr 2007
    40
    here it is. i think thats the tune i used. i went back to square one because of the ported TB
    Nov 2005
    Houston, TX
    3,968
    Sorry, can you post your config as well?
    Bill Winters
    Apr 2007
    40
    i think this is it?
    Nov 2005
    Houston, TX
    3,968
    NM, just import this histogram into histo 8. It plots the LTFT's against the MAF table.
    This is my V6 ignorance but are there two O2's? You are only logging one O2's mV and LTFT.
    I'd whack the misfire PIDs to increase the logging resolution.
    The fuel trims look to be pretty good to me already.
    Bill Winters
    Apr 2007
    40
    ok so its opened in the scanner and i got a bunch of numbers...now what?
    do you have AIM or yahoo? so much easier
    Nov 2005
    Houston, TX
    3,968
    All those "numbers" represent the fuel trims at the different MAF Hz. So if you take your log and plug it into my histo you see that @ 2250 Hz you have a +6 fuel trim. Multiply whatever number you have in your MAF table at 2250 Hz by 106%. The easiest thing to do is select all from the log and paste special, multiply by % into the MAF table in the tune. Flash, reset fuel trims and do another log, the fuel trims should be better. Once you get close you should start doing paste special, multiply by % - 1/2.
    Not 100% sure about the V6's but the whole point is to get the fuel trims ~0 or preferrably slightly negative. If you have positive fuel trims then when you enter PE it adds extra fuel on top of what you command.
    Bill Winters
    Apr 2007
    40
    how do i reset the fuel trims?
    Apr 2007
    40
    i got it!! thanks!!! they read 16.4 on start up for a few mins and then sits at 0..thanks!!
