I've got a 2000 Camaro, 226/230-112 cam, ported heads and I'm trying to tune the ve table-open loop sd, but everytime I start the car the afr at idle will be 14.7 for about a second then just shoot up to 18.0 and stay there until I drive it for about 5-10 minutes then comes down to the 15's and finally settling between 13.9-14.5. I'm idling at 900 rpms at 55 map and if you notice in my tune the ve value for that cell is around 29. To me that seems low and lean which makes me think the lean startups is associated with the that ve value but when it finally warms up it's rich. I could be wrong and maybe there is something I missed so hopefully someone could lend a hand and take a look at my tune to see if you see anything out of the ordinary. I would really appreciate it, this is driving me nuts. Also do you think if I enable the maf and scale that correctly that it will help the lean issue or do you think I need to tackle this problem first then continue with the maf and enabling closed loop? Any advice would be great, thanks, Mike
