I will try to keep this short.
402 with stage 2 ported heads 228/228 cam and equal length headers, lucas 42 lb injectors. Mail order tune.
The motor has around 800 miles on it and runs pretty well, but developed a stumbling problem almost immediately. I have changed the o2 sensors, plugs and wires; triple checked for ANY exhaust or intake leaks and looked at anything else I can think of. I just put on 8 new coils. I checked the fuel pressure and it is rick solid and I installed another new fuel pump. Every part on the motor is 800 miles old or less.
It runs perfectly when it first starts up but then develops some break up when you open it up at lower RPMs and tit is not making all of the power it should be.
I got HP tuners and started taking a look around. What I found was that the LTFTs at Idle are going positive around 10-15%.
I decided to see if the VE table was off so I followed the standard procedure to check them out and found that they needed some fairly large adjustments, which I made and the LTFT when operating in SD mode are pretty good (not as good as with a wideband, but before I go and get 2 widebands I want to make sure that I am headed in the right direction) and the car drives somewhat better.
Interestingly I noticed that the behavior of the OS sensors change the SECOND I disconnected the MAF - before the sides were differed by 5% or so. In SD they acted like you would expect.
After I finished tinkering with the VE table I reset the PCM to re-enable PE and plugged i the MAF and the os sensors and Fuel trims IMMEDIATELY went back to their old ways. leading me to suspect that it is the MAF sensor that is bad.
Any ideas. I am stumped.
I will attach some log files and the tune file.
