I have a 99 K2500 454 Suburban and somewhere in its life, someone swapped in larger injectors. How much? No idea. I suspect to run moderate to high doses of E85, but I cannot be sure. It was a corp vehicle at one time, for around 80K miles of its life.
Is there anyway that I can calculate what they might be?
Stock is around 18-19 lbs/hr @ 43.5 psi (but GM forces 63 psi on them, they are really 22 lb/hr flow). I am tempted to put in my old good LT1 injectors (24 lb/[email protected] psi) simply because I know the flow rate. Or get a set of LS1 injectors and use them, again, for a known flow rate. I really don't want to be stuffing $$ into good injectors to replace good injectors if you know what I mean.
What I see on my datalog is it is ALWAYS 18.0% rich (both banks -18.0% LTFT, precisely 18.0%, almost NO variance at all). Always unless in decel or a couple rare times, it is pretty stable, but always 18% rich.
I can lean it out with a healthy does of E85, but that is only a tank by tank fix.
I don't have a tuning program yet, so I can't tune it myself, else I would just take slow steps to guess it out that way. My tuner is mail order and will fix when I tell him what I need.
Is it as simple as plugging in 18% fatter injectors into the injector flow constant? If running on pure gas, I get rich bank 1 and 2 DTC's, if running 10% ethanol, it helps slightly, but stays rich and sometimes trips DTC's. If I run 50-60% E85 and the rest gas, I get nearly dead on perfect LTFT. Sheesh, on cold start it blows black smoke out the tailpipe. And mpg sucks even for a 454.... And if you are wondering, everything else checks out fine, FPR, MAP sensor, Vapor Canister, new O2's, etc, and not a single one of those would lead to a perfect 18.0% rich condition, on both banks.
Thanks!
