I'm attempting to tune my map in speed density mode. I believe it is running in sd, it didn't the first try and would not even run. I logged 5 or so runs and everytime from 3200 rpm's and down the stft's stay way negative. Everytime I keep taking away 20 percent on the table and resetting the trims but doesn't seem to help. I nearly zeroed the lower range out to see what would happen and still had negative trims. From 3200 and up they were on the positive side. I've added to them and got them to lower to a negative. I've included the last log. Can anyone see what's happening? I've unhooked the MAF but do I need to remove it from the charts?? Thanks
Attachment 8588
Attachment 8587
