Results 1 to 17 of 17
Thread: VATS disable on LBZ
    Sep 2006
    8
    VATS disable on LBZ
    I have a Hummer H2 with a LBZ drivetrain dropped in it and the motor would start up then turn off 2 sec later, it is acting just like the VATS is turning it off. So i disabled the VATS and nothing changed, still turns on then 2 sec later turns right back off.
    This H2 does not have the BCM to go with the LBZ pcm, do i need the BCM as it works with the VATS? I thought just disabling the VATS would eliminate the need for the BCM.
    Any input would help.
    Jul 2007
    Lombard, IL
    5
    i seem to remember that some years of DMax's had issues with the vats and were nearly impossible for swaps. There are some companies that specialize in the saps for surburbans and they would be best able to help you with what they have learned in that area. I recently read a piece on it, it may have been the oct issue of diesel power.
    good luck
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    In most vehicles you also must set the vehicle security codes to no error reported.
    Oct 2008
    10
    X2 on this VATS issue, I just bought my VCM tunner from here hoping to use it on my conversion and the VATS is still present
    HELP
    Oct 2008
    10
    I tried disabling th dtcs for security and also VATS disable (again), still runs for 2 seconds. Any sugestions????
    Advanced Tuner Programmer's Avatar
    Jul 2007
    244
    I don't believe HPT has the VATS value correct, so you won't be able to do this until they get it solved.
    Oct 2008
    297
    hit and miss also with the v6 cars, some work some dont
    Oct 2008
    10
    This was the sole purpose for my vcm purchase. Any idea where I can have my ECM programmed to erase the VATS??
    BILL... any update as to when this feature may be available?
    If you haven't already please email your file to support. I was sure i double checked all these after Lyndon first raised an issue. I'll check again.
    I count sheep in hex...
    Oct 2008
    10
    Hey Bill
    I emailed you the file and serial number on 10/30
    Did you guys ever findout why my vats still active?
    HP Tuners Support
    (foff667)
    28,268
    Our head engineer was looking into it, he found a couple of things it might be. I'll follow up with him tomorrow to see where he's at with it.
    Oct 2008
    10
    I apreciate your suport with this issue.
    HP Tuners Support
    (foff667)
    28,268
    We've added some new vats tables for the next beta version due out in a few days time.
    Oct 2008
    10
    Is this something I can download and upgrade on my software?
    HP Tuners Support
    (foff667)
    28,268
    Since you emailed support you will receive an email from me directly once the update is ready with download instructions.
    Oct 2008
    10
    I apreciate your suport with this vats issue.
    I am really impressed with the ethics arround here, you guys are on top of everything
    THANK YOU
    HP Tuners Support
    (foff667)
    28,268
    New beta up with several new VATS tables in the LBZ calibrations, I've posted the beta for ls1andvortec as well as programmer's accounts. If anyone else would like this beta please email support with your serial number & a link to this thread.
    Thanks,
    Bill
