All tests run with n-Heptane (0.6855g/mL) @ 20oC (+/-1oC), 3.0 Bar (+/-0.01 Bar), 14VDC (+/-0.05VDC), saturated driver wtih RC cutoff.
Gas (0.735g/mL) ratings converted at a 1.035:1 ratio.
Static Flow Rate (GAS): 62.7 lb/hr = 646 cc/min = 474 g/min
Dynamic Flow Rate 2.5ms PW @ 100Hz (GAS): 20.2mg/pulse
Coil Resistance: 12 Ohms (This high-impedance injector will work with all factory ECM/PCM injector drivers)
Gain: 0.11ms/mg
Offset: 0.055ms
Turn on time @ 14VDC: 1.14ms
Turn off time: 0.85ms @ 600KPa
Factory Tolerance: +/-6 %
Spray Pattern: Cone (4-Hole)
Factory fitted with Viton upper and lower o-rings.
Grease supplied to lubricate o-rings prior to installation.
Dynamically flowed and grouped to within 1% tolerance using Racetronix custom injector flow bench
