Hi guys,
I just had a power run on the dyno and we have noticed that we were only getiing 88.2% throttle and load was 98%. Can I have a senior tuner tell me why I got that and what do i do to get 100% throttle plzz.
thanx
ve ssv 73
Hi guys,
thanx
ve ssv 73
http://www.hptuners.com/forum/showthread.php?t=9700
See the 4th link down in the "Read Me" sticky.
-Matt
1970 Corvette LS1/T56
2001 Corvette Z06
What he said, and I would add to that:
The max throttle opening occurs at %TPS reading of 88%. The Corvettes and GTO's are allowed to go this far but the non-performance cars and truck engines are only allowed 83%. This actually leaves about 10ยบ of mechanical throttle blade travel unused in the non performance cars. This is a limit set by the PCM.
ETC is the PID you want to see if you just want to see something read from 0-100% throttle, but, it's one step away from the actual throttle opening percentage. If you notice during a run, the throttle body will open to 83% at less than 3/4 accellerator pedal travel, while ETC will vary to the limit. GM has designed in a ratio of ETC to TPS% that no one has been able to notice in their tuner products yet, although it should be apparent simply by comparing the binary code for throttle actuation ratios between the Vette/GTO LS2 and the Truck/non-performance car LS2 PCMs.
BTW: The %TPS is NOT a direct 1:1 ratio of how far the throttle is open. It's a ratio of the TPS voltage and the bottom limit seems to be between 20-25% TPS reading with the throttle blade mechanically on it's closed stop and the upper limit will read 88% with the throttle blade mechanically on it's wide open stop.
Actually it's more of a liability issue as to why it's not in there. HPT knows the code.Originally Posted by BBA
Remember the first A.U.D.I DBW issues? Accelerates Under Demonic Influence
Always Support Our Troops!
I'll take your word for it...never messed with Audi's other than changing blown head gaskets and fried alternators. But I did beat one cocky audi driver down pretty bad today on the way home from work, do these people actually think an audi is fast or something?Originally Posted by EC_Tune
