i just tuned a 07 cobalt ss on the dyno. and for some reason in the standard imperial config. it has the knock retard histogram, unsupported? can you not log knock retard on a cobalt ss, or is there something i need to do.
you can log it. you need to have it set up in your main table on the scanner I beleive though. I have it logging on my 07 SS.
the default config is the default was initially designed for 02 LS1 fbodies, you might need to customize it for other year/make and model vehicles as you could imagine what might work for an 02 V8 LS1 car might not work the same for a duramax diesel or Ford V8 or even a 4 cyl GM vehicle
BTW we do have a config repository for instances such as these http://www.hptuners.com/forum/showthread.php?t=9331
