Can any one help me as to why i am having such high injector dutys? and i am wondering if the advance looks funny to anyone else. I am running a equivelent to stage 2 tune, with a 3.0 pulley, 42# inj, cold air intake, and corsa cat back
i forgot to mention its a 06 cobalt 2.0 sc
try this for IDC
[sens.112]*[sens.70]/1200
I sent him a copy of the GM Stage 2 equiv. His injector duty rates exceed between 110% - 130% at about 6,000 RPM (3in Pulley). When he was on a 2.8 pulley (we all know not a great idea), was sitting at 140-150% IDC.
He still has a CAT. I recommended checking injectors for them sticking, ditch the CAT and if he has an intake going back to stock airbox.
I have a friend with a 06 SS/SC his injector duty cycle is also between 110%-130% under WOT. He has a Gm stage 2, and was tuned on the dyno a week ago. On the dyno the IDC was only 46%.
thats what im using right now doc
Sounds to me like 50+lb injectors would be more ideal.
Something is wrong. He is seeing higher numbers than someone using 42's and a 2.8" pulley.Originally Posted by Bill@HPTuners
This is an updated Stage 2 tune for a 2006.
I am curious if the other config file solves things. Either way, this tune is newer than the one you posted.
Show me the tune & scan from other said vehicle.Originally Posted by Doc.SS
The other cars I have done setup like yours were all in the same range mine included when I had my 3" and 42s in it.
is there anything wrong with the tune that would be causing high IDC????
Yeah just running the numbers through a rough injector sizing estimator says to get to 90% IDC with say 300whp you'd need 50lb injectors rated at 43lb/hr if your fuel pressure is at 58psi(not sure if thats what cobalt's run, just an educated guess really)
not that I can see.Originally Posted by expertauto
my asumption is that it should run with no problems with this tune because it is "gm stage 2 tune" with "gm stage 2 pulley and ingectors" or am i wrong?
Cobalt Stage 2 Performance 245 hp Upgrade Kit 17803229 Description
17803229 Stage 2 Performance Upgrade Kit, Cobalt SS/Saturn ION Redline
For 04-07 Saturn ION Redline And Chevrolet Cobalt SS only. This Kit enhances engine performance to 245 hp (up from stock 205 hp). Includes high-flow injectors, supercharger pulley, new special length supercharger belt & specific performance engine calibration.
this is gms specs so your 300 whp is a little high of a estimate
Doc I guess we can try the stage 2 tune that YOU have however I believe the problem is not with the tune as it is something related to the hardware (GM Stage kit) that may be causing the issue.
Even at a 250hp estimate 45-46lb injectors is the estimated need.Originally Posted by expertauto
Undersized injectors generally means you'll have high IDC's
This is from a 05 SS/SC with 42# injectors and a 2.8 pulley. Its using the exact tune I posted.Originally Posted by Bill@HPTuners
Ok so you've got an injector duty cycle of 120%. Was your run on a dyno?
Either way its well over the point of making injectors no matter if your at 120%, 125% or 130% lol
