Page 16 of 16 FirstFirst ... 61213141516
Results 301 to 310 of 310
Thread: Redline/GXP owners step inside
  1. #301
    Apr 2008
    Yorkville, Il
    21
    Quote Originally Posted by black06g85
    Let me clear this one up:
    My car = 411whp stock motor, clutch, fuel rail. (a bit more now with better fuel system, can't dyno cause I finally killed my stock clutch) (new one goes in on aug 16th hopefully)
    Hahn's car 440whp not stock motor, everything built but the sleeves, and well, I'll leave that alone.
    465whp (supposed by ZZP) twincharged, but still have not been shown any real proof of numbers and I believe is total bs because stock cams will not support that air flow.
    Small clarification department: The car is not Hahn's, but a local chicago-area fellow's. Poor guy thought he put in an engine with heavy-duty sleeves...when all it had was bore-in replacements of stock dimensions. It made 440 WHP on 20 PSI, 93 octane pump gas without meth. It will see its true potential at higher boost levels
    We are very proud of black06g85's numbers, as they were achieved using Hahn Cobalt products: StreetRace intake manifold, front-mount intercooler, and Billet blow-off valve. Great job man !
  2. #302
    Advanced Tuner black06g85's Avatar
    Jul 2006
    New York, New York
    277
    yeah kinda didn't want to say that publicly..
    but yes I use all hahn's parts on my car now (minus a few things I did myself before their kit was out).... great stuff by far.
    and that car (the 35r car) is going to make some serious power once it's ready for high boost.... making me want to get off my ass and tear my motor down.
    and btw my car's up to 440whp/400wtq on 104 octane and 414/378 on 93 ( a bit higher now with the colder weather, but haven't been back to the dyno..... yet)
    2006 cobalt (no more turbo)
    m62 2.7 pulley, E85, 79lb/hr injectors, 4-2-1 longtube header, airbox mod, stock catback
    1998 Trans am 5.3 iron block 317 heads 88mm turbo e85 105lb/hr injectors, twin 255's.... build in progress
    2014 wrx mild tune 18psi pump gas
  3. #303
    Apr 2008
    Yorkville, Il
    21
    Quote Originally Posted by black06g85 View Post
    I'lve already forgiven you for letting it slip
  4. #304
    Jul 2006
    New York, New York
    277
    lol thanks
  5. #305
    Dec 2005
    Las Vegas, NV
    9
    First off sorry for the newb questions...I did some researched and skimmed through all the solstice/cobalt SS/HHR SS/LNF threads I could find and some things still aren't clear to me.
    It sounds like some tuning parameters/tables are available for the LNF engine, but not as much for the solstice compared to the cobalt/hhr?
    If there is more available for the cobalt/hhr, is it not possible to reflash the solstice computer with a cobalt/hhr OS/tune?
    No transmission tuning is available for these vehicles with automatic transmissions?
    If anyone can clarify this I would appreciate it. I'm really chomping at the bit to swap one of these engines into an older Chevy but need to know I can tune what I need to to make things work correctly. I've already completed a few LSx swaps but haven't delved into the Ecotec world much.
    98 Chevy truck RCSBFS 2wd/5.7L/4L60E:drive:/Paxton Novi 2000 S/C @ 7psi / Megasquirt
    72 Chevelle LQ9/4L80E/GT42 conversion in the works
    http://www.ls1tech.com/forums/showthread.php?t=449129
  6. #306
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    As far as I know there are about the same amount of tables/params for each.
    Depends on the application & TCM, for instance we DO support some HHR 2.0t/ A4 combinations, however DO NOT support the A4 TCM in the Solstice 2.0t. You WILL be able to tune the pcm in those applications, just NOT the tcm.
  7. #307
    Dec 2005
    Las Vegas, NV
    9
    Thanks for the quick reply Bill. And my understanding is that there are no plans to support for the Solstice A5 5L40 trans?
  8. #308
    HP Tuners Support
    (foff667)
    28,268
    Its behind several other projects we are working on so no ETA at this point.
  9. #309
    Nov 2008
    1
    Can anyone confirm the new version allows the tuning of PSI, etc before I buy this.
  10. #310
    Aug 2007
    503
    Quote Originally Posted by jctusmc03 View Post
    There's like a dozen lnf threads about this... yes you can.
