I've had no luck figuring out how to upgrade my license to include a 2 Bar OS on my car. How do I license a new OS?
RHS Block 427, Mast/ PI 275 Heads, A&A YSi SC, 3.125Pulley, 238/254 LSA116+5, Flip Drive, AR 1 7/8 Headers, Corsa Touring Cat Back, RPM Level VII Tranny/ Flexplate/ Drive Plate, PFADT Carbon Fiber Drive Shaft, RPM rebuilt DTE Stage 4 3.42s, Vigilante 3 Disk 2600 converter, Custom Fuel System with Dual A1000 Pumps, ID 1000 injectors, Triple Nozzle Alky Control, 3 Bar SD Tune using 2.5 MAP. 935rwhp 800rwt
I hate to be that guy but did you read the help section? it has a write up in there that i'll be doing this weekend
02 Z06, A&A supercharger, 60# injectors, 7 lbs of boost, LC1 wide band
I'm trying to figure out how to purchase the license for the 2 Bar OS. Do you have to email sales to purchase it or can you do it online?
I've seen that help file. In it, it shows the OS is "not applied" to the tune it uses near the beginning. Mine show the OS is "unlicensed". I can't figure out how to get the license so I can use the 2 Bar OS.
If I follow the help file I end up with "unlicensed- Applied" on the OS page.
are you using older Serial interface or MPVI?
If you are using serial you need to follow the instructions in your customer login to do the upgrade (you need to email us your file and we provide a new software download for you). If you are using MPVI then you just apply the change and license when asked.
Chris...
I count sheep in hex...
Got it, I just needed to click write all....
