Thread: Changing Electronic Throttle Parameters & others using V2.2.0
    28,265
    Exclamation Changing Electronic Throttle Parameters & others using V2.2.0
    If you were running an early version of 2.2.0 when you read your pcm changing any Electronic throttle tables as well as many other tables within our software on Fords you MUST disable both the IPC ROM Switch & IPC ROM Enable drop down parameters or you will get a SES light & probably a wrench light not to mention going into reduced power mode.
    This will be fixed in the next public update but for now that is the simple fix to this issue.
    -Bill
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    this should be a sticky!!!!
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    28,265
    It has been.
    Mar 2006
    Kuwait
    1,564
    great, just saw it
    Bader Norris
    MEP Tuned
    Instagram
