This is realy just a general question - right now my trans seems to be okay. The fluid is fine and it is shifting.
Since we have in HPTuners the ability to log the trans gear, trans input rpms and the trans output rpms. Can we then set up a formula in Excel, that based on the data dump can be used to determine how efficient the trans is operating.
As I understand it - we can figure out the rough torque converter efficientcy by dividing the trans input rpms by the engine rpms at WOT.
Can this thought process be extended to also look at how the trans is working from the input shaft back to the output shaft. The conversion - if it makes sense - would be to:
1) dividing the output shaft rpms by the input shaft rpms @ WOT.
2) The resulting figure should be close to the gear ratio of the trans for the specific gear.
3) There would be some error - due to friction losses - but unless my logic is really off - it should point to whether or not the clutches are okay.
I maybe overly complicating this - but I am just tring to see if the logic is right.
Steve
