We are now Tech Edge dealers so if anyone in HPT land wants one PM me or email for pricing, all pricing listed here is in AUD, shipping to USA is no problems at all,
After trying just about all the cheaper wide band systems on the market and being dissapointed with there lack luster performance and lack of accuracy we tested the Tech Edge products, what a difference, they are spot on accurate, easy to configure and for the price they can not be beat!
Tech Edge offers everything from the Basic 2J1 (which we are running in the race car) to a full data logging system with single or dual WB channels with 1mb of storage, which will log up to 1 hour at 10 samples per second, all units have a standard 0-5v 9-19afr output,
3 different styles of displays cap of the packages,
here is a basic run down on the products and some pricing
2J1
This is the basic controller, no on board logging and has fixed length cables that are long enough to install into 90% of cars, 0-1 and 0-5v outputs standard as well and inputs for external logging to a laptop etc,
pricing starts at $280 for control box and sensor,
2C0
The 2C0 is a miniture controller, it has no on board data logging but is a little more flexable than the 2J1 as you can choose the length of cables you want,
still has the same inputs and outputs for logging to a external device.
pricing starts at $450 for control box, 2.6m sensor cable and sensor
3A/3E
the 3A/3E range has a lot more functions and is also avaliable with 1mb of memory for on board logging, they feature 3 0-5v inputs for sensor logging, 4 temp inputs for EGT logging, these can be converted to 0-5v inputs if required, they also have a rpm input and a VSS input to log wheel speed as well as the standard 0-1 and 0-5v 02 outputs,
the 3E range features a inbuilt display so a seperate one does not need to be purchased
pricing starts at
$505 for a 3A1 with no logging,
$531 for the 3A2 with 1mb of logging
$555 for the 3E1 with inbuilt screen, no logging
$582 for the 3E2 with inbuilt screen and 1mb logging
3H1
The 3H1 is the dual channel system, perfct for the big V8 that requires 2 sensors, both sensors have a 0-1 and 0-5v output so they can be logged seperatly, 1mb of on board logging standard, 6 analog inputs and rpm inputs
pricing starts at $855 with 2 sensors and 2x 2.6m sensor cables
3B1
The 3B1 is the big daddy single channel unit, it features 1mb of logging, 6 analog inputs, 2 speed inputs, 0-1 and 0-5v 02 outputs
pricing starts at $565 with sensor and 2.6m sensor cable
all systems come with the required cables to hook up to laptop for data logging etc,
DISPLAYS
LA1
the LA1 is a 52mm round display for dash mounting or guage pod mounting,
avaliable in both red and green readouts
price Red $185 Green $190
LD02
The LD02 is a large readout display avaliable in both red and green readouts,
price Red $155, Green $165
LX1
the LX1 is the newest dispaly, it is a LCD readout that is back lit for night use
the screen is 45x20mm in size
price is $155
here is a pic of the 2J1 mounted in our race car
for all pricing or product enquirys please PM or email me [email protected]
Dale
