Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: 4wd to 2wd tuning
    Jul 2005
    arkansas
    530
    4wd to 2wd tuning
    i'm looking to swap from awd to 2wd. i think i have about everything figured out. execpt for the service 4wd stuff. i think thats controlled by the bcm correct? or can i just unclick it all in hpt for the pcm? my tahoe has stabilitrack also. i would like for that to still be able to work somewhat for winter driving incase i need it. other wise it will be tuned out for all other seasons.
    '04 Tahoe AWD, trickperformance turbo kit, TC78 turbo, 4"magnaflow muffler, Circle D triple disc 3,000, FLT LVL 7 4L60E, L92, 227/235 111lsa.
    Old 5.3=12.33 @110mph
    http://www.streetfire.net/video/turb...mph_741849.htm
    Dec 2007
    Chesterton, IN
    16
    What year Tahoe are you working with? 2004 I assume by your signature...
    Scott McKinney
    SMM Performance Parts
    219-241-1099 PHONE
    888-618-2510 FAX
    www.GoSMM.com
    Jul 2005
    arkansas
    530
    yes 2004 with borg warner transfercase. i took a look and it only has a speed sensor on it. no front and rear sensors. and the motor on the back.
    Advanced Tuner Programmer's Avatar
    Jul 2007
    244
    A more thorough explanation would be good. What are you building here ?
    Yes there are BCM related items, ECM related items, IPC related items, etc...it's going to be a lot more help if we knew what you're doing with your project.
    Jul 2005
    arkansas
    530
    well i am looking to install a t56 into my tahoe. and ditching the a4 and awd. also installing a 383 ls1 stroker motor (eagle stroker kit). don't worry i have been insured that the built t56 i'm getting will hold. also going to a 4.88 rear gear to make gearing with the taller truck tires alittle better.
    all you need to do is unplug your transfercase control module it directly tells your cluster to display the service 4x4 light. no module = no can message = no light
    Jul 2005
    arkansas
    530
    really? didn't know that.
    Advanced Tuner Pro Street's Avatar
    Aug 2006
    806
    244
    Quote Originally Posted by scotte
    Where is this at?(TC control module)
    2018 GMC Denali A8 6.2L
    2016 CTS-V
    2016 C7 Z06 A8
    2016 C7 Z06/Z07 A8 vert
    2015 Chevy SS 6.2 LS3 A6
    1996 Impala SS LT1 CAI
    1995 Chevy 1500 5.3 CAI Z06 cam
    1957 Chevy vert
    Jul 2005
    arkansas
    530
    i think he is talking about the push buttons on the left side of the dash. if not then i'm miss understanding also.
    i'm not talking about the buttons there is a seperate control module in the dash i have a pic (from the gm service manual) but nowhere to host it
    Jul 2005
    arkansas
    530
    if its not to big you can host it here. or email it to me and i'll put it on photo bucket. or you can open your own photobucket for free and host it.
    your not talking about the body control module are you? its kinda under the steering wheel shaft in the dash. hope not cause you need that to run all the other body stuff.
    there i figured it out
    Jul 2005
    arkansas
    530
    lol looks like the bcm. no bcm the the truck won't work at all.
    if thats the bcm i wonder what THIS IS
    heres an exerpt from the gm service manual
    Service 4WD Indicator
    The SERVICE 4WD indicator is an integral part of the cluster and cannot be serviced separately. This indicator is used to inform the driver of the vehicle of malfunctions within the FT4WD transfer case system. The SERVICE 4WD indicator is controlled by the transfer case shift control module via a Class 2 message.
    and heres another pic of the tcs control mod if i had to guess i would say its located behind the glovebox maybe
    Jul 2005
    arkansas
    530
    ok, i'll look tommorrow. i looked under the driver side and found the second pic you showed. i have the service manuals for 04 silverado but not tahoe i wish i had them. my transfercase info is not in my silverado manual.
    thanks for the info.
    Jul 2005
    arkansas
    530
    so is this thing maybe behind the heater duct stuff. i can't find it anywhere. i'll try and look harder but i can't find it.
    i think its behind the heater assy almost on the firewall (ugh)
    i do have another option for you thou but i'm not sure if it will work
    there is a 30a fuse in the fuse block(underhood) labeled "TREC"
    according to my service manual it provides power to the transfercase encoder motor and the module and nothing else
    i would try pulling it
    technicly speaking no 12v+ = module not on = no class 2 message
    = no light
    Jul 2005
    arkansas
    530
    that may work too. i'm still awd at the moment i need to figure out a way to test this. if i unplug the encoder on the t-case it should set a light right? then if i undo the fuse and restart the truck the light should be out because the module didn't send the code. right? then plug it all back together until trans swap time. now for another question. will my stabilitrac still work? i think mine has a sensor on each wheel which tells the pcm/bcm if there is any tire slipage. when it senses slipage it just applies the brakes to that tire to stop the spinning. there are no sensors on the t-case besides the one speed sensor and the encoder module. i would like for the stabili trac to some what work still because it would be good to keep the rear end under the truck during daily driving. and it helps for over and understeer and such.
    now with that said i need to be able to turn it off. the only way to completely shut it off is to hit the 4lo button. or for the pcm to get the 4lo signal. which i think is a ground it may be a 12 volt signal but i could just hook up a push button switch with ground or 12vdc and hook it to the wire. just thinking outloud here. does you service manual cover my tahoe or is it general?
    i would just pull the fuse and if you dont get a light i would say your safe
    weird things can happen to encoder motors when disconnected and the module powered up (i.e become unsyncronized)
    yes there is a 4x4 low wire on the pcm but you will set bcm codes (not erasable via hp tuner (to my knowledge)
    if it was me i would tap into one of the wheel sensor wires and put a relay on it- when disconnected you will get an abs light and traction control,abs, and stabilitrac will deactivate) hook the wire back up and then do a key cycle and the abs light will be on untill you hit 8 mph (according to the service manual) and the light will go off and you have everything again
    to answer you final question i i'm accessing gm si so i'm looking at the tahoe manual
