Hello,
I am attempting to run my 2.4 s/c on E-85. Currently I am running a 50/50 mix but I'd like to go straight to 100% if my IDC's will allow it.
I am working on flashing a new firmware into my wideband, but it will only go from 4.5 to 8.5 afr if I do this, and E-85 is 9.76 stoich right?
At wide open on 100% E-85 and full boost I'd want 6.9 ish AFR?
I understand I can set stoich in the editor to 9.76, but what is the flex fuel setting in my VCM? Can I simply enable this and if so what does it do?
My biggest concern now is the IDC. I have 60 lb injectors but I am already seeing 94% IDC at about 11.20 AFR.
The only other way I can think of to tune this is like a carb on a dyno and add fuel until she noses over. Any help would be greatly appreciated.
Here is a rough log file, I've not done any LTFT or STFT tuning as yet, just open loop WOT, so please don't hammer me for the crazy afr down low.
Thanks Again
Jim
