I think I'll need to refer to this later
I am trying to walk through this and can't seem to find anything called the "idle spark table". Is this the "Idle spark advance"? If so, Base or Coast down?
Thanks in advance.
Thanks for your patience, but I don't want to assume I understand your response and make an error. Not sure what "make them match" is in reference to.
The instructions in post 85 called for putting the corresponding values from the HO table into the idle spark table. I could not find a table called "idle spark table" and the instructions made no mention of Base or Coast down, so I was not 100% sure I was looking at the right table.
Go to Spark > Idle Spark Advance > Base.
There are differences in opinion here. On my 2005 Corvette with a mild head/cam set up, I left the High Octane spark cells almost stock and left the idle spark base and coast down tables close to stock. Just added a couple of degrees. But a more radical set up may like more advance at idle. Mine tune works well with 17 degrees at base idle and coast down tables and 31 degrees on the High Octane table.
My understanding is the High Octane table sets the ceiling on ignition advance. Then stopped, the idle base timing table takes over and it uses the idle over and under speed tables to add & subtract advance to keep the idle RPM reasonable.
Depending on the amount of torque your head/cam set up makes at idle, advance can make a huge impact on keeping the idle RPM good. Here is what you have to understand. If, for example, your engine makes its maximum torque at 26 degrees at 800 RPM, then any air flow or timing changes have a lot more impact on idle RPM than, say at 16 degrees. So what you may want to try is set the base idle timing between ~16 degrees so it is less sensitive to any airflow or timing changes. It also give the timing over/underspeed tables room to work. A big, nasty cam with lots of overlap may need 25-30 degrees in the base idle table so you may need to experiment here. I don't know what your set up is so I can't give you a hard and fast rule.
All of this is fine IF the VE and MAF tables have been calibrated at idle. Your air flow tables must spot on first before tweaking timing. If air flow is not right you will end up chasing you tail.
This is not just me speaking but it is also the advice of the experts including Greg Banish.
2014 Corvette, Z51, 3LT, 7-Speed, NPP, 2 tops, Exposed Carbon Fiber roof, FAY, Laguna Blue, Kalahari, Museum Delivery.
Thanks Mez! I am just trying to learn now and do not plan on changing anything for quite some time. Your post is very helpful.
Can someone take a look at my tune and give me some pointers? It idles fine 80% of the time but occasionally right after startup and sometimes coming to a stop the idle will flare and dip a bit, 1200-600. Like I said, not all the time but something is still wrong. Car is a full bolt on 06 M6 GTO with a 231/235 .617/.620 112+4 cam. Thanks.
Can't really tell anything without a log taken with this config. Have you tried the procedure?
Bill Winters
Out of the LSx tuning game
I'm having trouble with the histogram. My 10 and 11 are blank so I guess I will have to try to custom make a histogram.
Here is a log of the flaring/dipping. This is coming off the highway on an off ramp coasting in neutral.
It doesn't contain what I need. Here is another config that uses MAF instead of dynamic airflow. You should be able to run through the procedure with it, at least histo 10 will work, I don't see why 11 wouldn't.
Bill Winters
Is there supposed to be something configured on 10 and 11? Cause I have the beta version I bought about 4 years ago and those are both blank. I think after looking at the log its timing related, the timing jumps to 29* or so and thats when it acts up. I will try to fix that and see if it helps.
Uh, are you tuning the car that your screen name is? Cuz this procedure is not gonna work for that.
If you're working off a 4 YO beta you need to upgrade. Contact [email protected]
Bill Winters
No its a 2006 GTO. When I use the VCM controls and turn the spark idle control on/off the idle doesn't change so doesn't that mean my RAF table is pretty good or no?
I donno man.
Bill Winters
2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
2023 Durango Hellcat
Shoot me your cam specs and tune to [email protected]. A log of steady state idle wouldn't hurt.
http://www.dsxtuning.com
Just say no to bull s***.
What do you want me to log at idle?
The basics. Rpm, spark, fuel trims, etc %, dynamic airflow, dynamic cylinder air, etc.
does this work with 09 CTSV with E67?
i opened the config file and found histograms 10 and 11 unsupported,, any work around?
car is an A6 and has a cam of -5 overlap,, idles good except for 100rpm fluctuation which shakes the car when D/R engaged,, is that accepted from such a cam?
09 CTS-V A6
