How to keep A/C comp. on more.....
I want the A/C compressor to run up to the WOT threshold. I don't mind a loss of power. I just want cold air blowing if I'm only pushing like 75% throttle. What can I change to do this? I did change the A/C enable and re-enable rpms but it didn't seem to change. Do I have to change the TPS% enable/ re-enable parameters also?
Thanks,
Joshua
Re: How to keep A/C comp. on more.....
Yeah, if you want it to stay on over half throttle you
will have to mess the TPS thresholds around too.
I believe it works like "disable above either, re-
enable below both".
