Originally Posted by
Quiksilverss
Hi Guys,
I have a 06 Cobalt SS Stage 2. I want to add a larger Throttle body as well as a meth kit. I want to only make the changes on the tune so that I can run a healthy a/f ratio in the low 11's. I am aware that for the larger TB I will need to change the ETC Scalar area to compensate for the larger TB. I am also going to run a 2.9" supercharger pulley. I have a progressivly controlled meth kit that I want to set to turn on at 7psi and be full spray by 12psi and up. I plan on using the smallest meth jetting.
I am aware that with the addition of the larger TB and pulley it will lean the car out (up to one full point) and I am also aware that meth richens the a/f up (approx 0.5 points with 50/50 mix)
I was told that in addition to changing the ETC SCalar area I would have to have my tuner make some changes in the pe table to help command the a/f ratio I want.
Can someone help me figure out what step by step changes that need to be changed in order for this to happen. I want to keep the stage 2 tune as close to stock as possible but to make sure my a/f ratio is safe accross the board
Thanks in advance
