I converted my '07 Trailblazer SS to e-fans (Corvette PWM style). The problem is the fans are not coming on till 217 degrees. They will slow as the temp drops but based upon the below they should be coming on at 192.
Anyone have any thoughts?
Please post a scanner log while logging fan status as well as your .hpt tune file.
From what I recall, anything past 91% desired fan speed equals both fans on at high speed. Below 90% is low speed for both fans, so your fans are not set to come on to high speed until 207 degrees. Otherwise they are on at a lower speed. Good luck!
