Results 1 to 11 of 11
Thread: 2.93 to 3.29 with 30tooth reluctor
    Sep 2007
    4
    Quick and probably easy one for you guys.
    I had my trans rebuilt back and while with 3.29's. A 34 tooth reluctor and speedo recal was added at the time to ensure things worked 100%.
    I changed the diff and put in a 30 tooth reluctor. Changed back the speedo recall to 0 and changed the drive sprocket ratio from 1.120 to 1.000. Speedo is on the money with GPS, shifts are harder than usual and TCC is locking and unlocking quickly.
    Found a year old post where John F posted a screen shot of how he got it to work and am going to try it next. Since 3.29's use drive and driven of 35 tooth each, my sprocket ratio should be 1.000 right?
    Thanks..
    May 2007
    Upstate NY
    132
    Yes, 1.00
    Do you have a link to that topic? I'd like to read it
    98 Buick GSX IS3 Heads/GenVblower/cammed/intercooled and stalled
    02 Collector Edition Trans Am WS6
    94 S-10 with Rancho 3" lift on 33's
    93 Typhoon
    07 Tahoe
    Aug 2004
    Chandler AZ
    117
    Damn... you speak geek.
    You went about that question in such a way that I forgot what you were asking by the time you finished it up.
    Best 60' = 1.716
    Best ET = 12.186
    Best MPH = 112.98
    Dec 2007
    Montreal, Quebec, Canada
    339
    Basically, the relutor tooth change is used to avoid making changes in the PCM code, thats the bottom line... lol.
    '99 Black GTP Sedan
    3.4-2.6" PB Quick Change pulleys, Custom CAI, XP Cam, N* TB, LQ4 MAF, SLP headers, 42.5# Injectors, 180/195* thermostat.
    13.501 @ 103.392 on 91 (2.4 60-foot).
    13.82 @ 105.28 on 87 octane! (2.42 60-foot).
    263kph top end as shown on the GPS.
    All this and 39MPG to boot. What more can a man ask for?
    * Just another enthusiastic amateur tuner! *
    May 2007
    Upstate NY
    132
    I remember reading that post now, i'll have to try changing the 3.29 value to 3.69, i can't figure out how the hell to get it to stop throwing that gear ratio code.
    93 Typhoon
    07 Tahoe
    Advanced Tuner louvered97gtp's Avatar
    Nov 2007
    Southern California
    202
    Likewise I'll be trying this saturday morning and see if i get resluts as well. same gear ratio as you guys so I'll switch to 3.69's and check.
    99GTP: Flowmasters, ZZP Power log & Ported rear, 9.5:1, Bored over .010, removed balance shaft, Dbl roller chain, Intense S1X, custom ported heads, 45#inj., 105lb springs, 1.7 rockers, A103's, 180-stat, Gen V swap, 97 Cadillac TB & Custom machined alum. spacer, 95 GTP Hood louvers
    97GTP: Stock engine, 95 GTP Hood louvers
    Feb 2008
    248
    how do i change the 3.29 in the calculated gear ratio to 3.69....this is how i was told to do it when switching from stock 2.93's to 3.29's...and this is the only thing you have to change
    2004 GTO LS1~HP Tuners~AFX W/B~PRC 227 heads~.644/.598-231/234-111(TQV3)~Kooks 1 7/8 headers~Stock injectors~Fast 102 LSXR Intake~Fast 102 TB~CAI cold air intake~Yella Terra Roller Rockers~Fast Fuel Rails~
    Dyno's are for sissy's, See you on the street.
    Nov 2007
    Southern California
    202
    Latest info I've heard is that changing the gear info in the PCM required many other changes to ensure everything worked correctly. No one has been able to identify what this entire process is. So the common way is as Jerry mentioned, to just change a reluctor wheel that mechanically adjusts your ratio seen by the sensors to continue working normally. Although it does seem possible via the PCM, it's just still a mystery at moment. I was told 2.93 and 3.29 gears did come factory installed on some GTP/GTX/Comp G cars.
    May 2007
    Upstate NY
    132
    Under the speedo tab, type in tire height (same as it already is) and a gear ratio of 3.69 commit. It will manually scale all your tables and adjust everything else, don't touch the vss numbers or sprocket ratio numbers. If you had 3.69s you'd type in 4.11 commit.
    93 Typhoon
    07 Tahoe
    Feb 2008
    248
    correct. thanks for the info.i didnt see where you type it in at first.
