I haven't read much on it, but I have a guy asking about it and got me curious. He was told that you couldn't SD tune a 98 car. Is that true? And what about a FI car with a 3 bar map can they use it etc... Thanks.
Yes you can speed density tune any LS1 (Gen III) engine. The 98-2000's had two VE tables: The low res one is used when the MAF fails and the Hi Res one is used when the MAF is enabled.
You can go up to 2 bar speed density with the 98's. They just don't have the additional space for 3 bar.
Always Support Our Troops!
I have a SD tune that EC TUNE did on my '98 Vette that has 591 RWHP and is FI.
My MAF tables would run out and SD is the only way to go!
Thanks,Matt
RIP - '98 LS1 Vette!
E-MAIL - [email protected] Cell 661-406-7516
Bolt on Mods with an A4 and 3:15's:---------322RWHP and 327RWTQ
TFS Head,Cam,Kooks LT's,Hi-FlowCats,X-Pipe:400RWHP and 400RWTQ
New Cam Yank 3200 Stall, 3.42's-------------423RWHP and 399RWTQ
ProCharger P1SC 3.85" Pulley 7.6 PSI Boost:565RWHP and 483RWTQ
Meth Injection2BAR SDTune(Est720 HP@Crank):591RWHP and 496RWTQ
Forged 347 3.7" Pulley FlipDrive, 14.4 PSI of B@@ST 701RWHP and 582RWTQ
Thanks that is what I needed to know. Why then on my 99 can I use the 3 bar map sensor if it was 98-2000? I know they changed the PCM in 99. Did they just expand on the tables or what.
99's use a completely different pcm
