Hey to all...
I have been trying to get my idle better, its not bad in CL but some surging and hunting, I have found the thread about running OL for your idle and I like that idea of a hybrid tune, and I think it could be more stable for your idle.
Question is, if you put your engine in OL for idle, I believe it will run off the OLFA table and I question the OLFA table in the area of idle such as my engine idles around 775 rpm and 46-48 kpa and at 212*-230* in the stock OLFA it is set to deliver like 15.45 afr, now mabee this wont hurt the engine but it seems lean for idle.
In the stock Z06 (i believe a 2001) LS6 which has different heads and cam and I dont know about CR, but I believe is about the same engine, and at the same 46-48 kpa, rpm and temp it has a command of 14.1 - 14.7 afr, and the only differences between the two tables are around idle and one other place....because of my cam, could I use the Z06 table and be safer for OL idle?
And BTW the Z06 spark table and some others look like they has more intelligence behind them than my 2002 LS1 table...just my observation,... And I always reserve the right to be wrong.
