I just recently recieved HPT (got it yesterday). I had time today to play with it a little bit
Car is a 04 Saturn ION Redline, 2.0L S/C LSJ..Mods are 3.1" pulley, cone filter, thats it
Since day one of the smaller pulley, above 6k rpms the boost fluctuates between ~14-~10 depending on temperature of coarse
Now I just raise my limitor slightly, and about 6400rpms Map drops suddenly to 121 KPA (about 3 psi) and stays or drops even more to about 6700rpms where I shift...all done in 2nd gear. I know GM had boost protection on 1st and 2rd gear on the LSJ cars above 6k
Now my question is, is the table that I want to adjust to solve this problem under Torque Mangement>Supercharger>Desired Boost under boost control? This table shows that is asking for 100kpa above 6250, which explains why the boost would drop/fluctuate erractly..but since I'm not playing with my car now, and rather not hurt it or waste time playing with it if its not going to work, I am asking here
if you really need I can upload a screen shot of the datalog, but I think I explained it well enough
p.s max boost is 100% is second gear all across the table so thats not the problem
Also I'll probably be asking alot of questions about different tables, because of the way they are worded and what not
Edit: I just noticed the Title, NO I do not drink.. supposed to say Boost if you didn't catch that
