Low impedance injectors?
What do you guys think about running low impedance 83Lbs injectors w/driver on an 04 GTO running on E85 that should put down 700hp at the wheels? Would I have an easier time tuning idle and mid throttle range? The car is 75% track and 25% street driving so I need some driveability. Anyone with any experience with this?
N20 or FI? I like to avg of 30%-40% increase E85 flow rate over gas for injector sizes. Whats your current size injector and what fuel pressure are you running and can you adjust your regulator?
you will need a convertor box to run the low impedance injectors... you know about that right?
