Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Raising shift limit on F150 Ford
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    I've been trying to do this time and time again with no luck. I set the 1-2 WOT shift to 5500rpm but it still changes at 4999rpm.... Any ideas on why this is happening?
    Also looking at the spark control, the X-axis tables limits at 5000rpm..Could this be a factor to why the truck won't shift at what I set it as? I've even tried changing the X-axis to a higher number of 6000, but the table display won't change....
    Please help, it seems the Ford software was put together very quickly
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,275
    Can you please post the file in question
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Try raising the WOT 1-2 shift speed (mph) by the % difference. The spark values at 5000 rpm are used at the higher rpm's.
    Russ Kemp
    Mar 2006
    Kuwait
    1,564
    here's the file, sorry should've posted it up before....
    Russ, I've looked for WOT speeed mph.. but couldn't find it... there seems to be a table but i assumed that was for normal driving gear changes... please let me know when u read the tune... so i can delete it.. thanks
    Bader Norris
    MEP Tuned
    Instagram
    HP Tuners Support
    (foff667)
    28,275
    I have no problem raising the spark axis http://www.thetuningdoctor.com/HPTun...s/fordaxis.swf
    -Bill
    Mar 2006
    Kuwait
    1,564
    oh nice one bill! see i was getting confused with why 4 tables had 5000 and 10 in them? I would've assumed it should have gone up in increments of 1000... but this seems to work nicely too, thanks for that!
    Bader Norris
    MEP Tuned
    Instagram
    HP Tuners Support
    (foff667)
    28,275
    ford does it slightly different than GM, not sure why but thats how its done.
    Mar 2006
    Kuwait
    1,564
    any update on why i can't raise the rev limit?
    Bader Norris
    MEP Tuned
    Instagram
    HP Tuners Support
    (foff667)
    28,275
    Can you post a scan showing the issue please I know for the ford frame rate is pretty poor but I would like to see what rpm/mph its showing to see if I can figure out whats up.
    Mar 2006
    Kuwait
    1,564
    sure... wish there were more parameters to log, specially since I can see I'm getting knock, but I can tell how much.. thank god for iron!
    Bader Norris
    MEP Tuned
    Instagram
    HP Tuners Support
    (foff667)
    28,275
    Quote Originally Posted by Trailblazin'
    Here's a pic of the upshift speed tables russ is referring to, in the meantime I'll see what info I can get on Ford shift strategies.
    Mar 2006
    Kuwait
    1,564
    with the GM shift times, I normally 0 out the WOT shift speed and rely mainly on the WOT rpm shift speed... Ill try this out on the pick up once it's out the garage.. the trucks getting a breath of fresh air (cam, intake and dynatechs) so ill be back with some more questions
    Bader Norris
    MEP Tuned
    Instagram
    HP Tuners Support
    (foff667)
    28,275
    Yeah im not sure if Ford does it differently or not, I'll need to have our engineer look it over.
    Mar 2006
    Kuwait
    1,564
    ive just tried the same way with GM but it wouldn't shift... when at wot it wouldn't rev higher then 3500rpms as if "spark control - TM" was kicking in...
    I'm gonna log the truck at WOT and see what mph its shifting at then adjust according the way Russ said... this is going to be fun with the 6min write times
    Bader Norris
    MEP Tuned
    Instagram
    HP Tuners Support
    (foff667)
    28,275
    Damn spoiled GM tuners lol, Ford pcm's will only accept write entires
    Mar 2006
    Kuwait
    1,564
    lol yeah tell me about it! plus the annoying door open chime constantly ringing in my ear... Fords are becoming a pain in the ass to tune, not like the fun of GMs trial and error tuning..
    Bader Norris
    MEP Tuned
    Instagram
    Mar 2006
    Kuwait
    1,564
    Quote Originally Posted by Bill@HPTuners
    any heads up on this?
    Bader Norris
    MEP Tuned
    Instagram
    Adjust the MPH for the shifts..... Upshift speed shows 50 from 1-2.. Check and see where the RPMs follow and then readjust where you want them.
    There are several items that need to be adjusted to get the speed of the shift at the RPM you want it to shift at.
    When in doubt use the MPH function to get you close.
    Adjust your upshift time also.
    TonY G
    TonY G
    TunersInc,
    164 College Dr
    Orange Park FL 32065
    904-276-7223
    Mar 2006
    Kuwait
    1,564
    Cheer Tony for the heads up... Is there a chance I can just change my higher MPH values and leave the rest as stock... Ive got the truck to shift at 5,700rpm now, the only problem is when at cruise it takes forever to shift from 1-2, 2-3..
    Ill decrease the values and keep the higher TPS% values the same and see how it goes?
    Bader Norris
    MEP Tuned
    Instagram
    Yes, you got it!!
    TonY G
    TonY G
    TunersInc,
    164 College Dr
    904-276-7223
