Hello everyone, I have been working on a start up tune file for my turbo cavalier project with a couple people...all of whom are more expirienced than I. I plan to get the car dyno tuned pretty much immediately, but I can not get it running. I have found out that it i dumping SO MUCH gas it is pooling in the dishes of the pistons (and probably down into the crank case). I as well as others, have gone over the file, injector constant, ve tables....pretty mcuh everything I can think of. Everything looks like it should at least start up and run...
Is there something I missed , is there some kind of starting procedure that needs done ? I would like to get this pig running this weekend.
I appreciate any and all help in this matter, and to Ryan @ p&p.. thats for you.
A little on the setup. 2001 cavalier 2200, 5spd. GT3071R turbo intercooled, fully built engine, MSD DIS 2 (for ignition retard under boost) with seperate 3-bar MAP, car running on stock 1 bar MAP, 500cc injectors. Any questions please ask.
I am attaching a copy of my tune, actually this is the tune Ryan and I worked out (most of the credit to Ryan of course), and he sent me under a license year he had. I transfered ALL tables over EXACTLY to my file, and will attach a copy of that tonight (not loaded onto this PC). Once again ANY help is GREATLY appreciated.
