Anyone know if this is possible?
I have a 2006 GTP tranny that I got for a project. The project is a 3800 but it is a throttle cable engine setup. I figure I can not run the 2006 Throttle by wire setup on an engine with a Throttle cable. (or can I?)
I was planning to pick up an older PCM from back when the 3800's were still using throttle cables. I am a bit worried that the ecu wont run the newer transmission though.
Anyone have any insight?
