Can somebody tell me with hpt how to set airflow to rpm the table I see is g/m vs hz I know with ford 5v you can make airflow match rpm by scaning it and changing it to match from idle to redline.would like some help
MAF is a 2d table with frequency Hz on the x Axis. There is no RPM associated with the MAF function as you can have multiple RPM's per MAF point. MAF only measures air.
Can you be more specific on what you are trying to do?
Always Support Our Troops!
This car has 6.0 truck short block and they put up any mass sensor they found. I'm new to tuning EFI I have been working with EFI from 1985 but not tuning I have a transmission shop and been here from 1994 I add a dyno and starting a little tuning . I know with ford if the mass does not match or not cal. right nothing right ford work off 5v and gm works hz I guess I need to model the air to match . Thanks Trent
From RockAuto.com ACDELCO Part # 2134160 {#15904068}
Is the casting # mean anything as part #
Don't know unless it matches that part number above.
