Page 3 of 3 FirstFirst 123
Results 41 to 55 of 55
Thread: hesitaton problem
  1. #41
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Post log/layout you're using.
    MAF is literally just mass air frequency and either fuel trims or EQ ratio error or whatever you want to put into the graph... not much to it. Usually the problem is not logging mass airflow frequency
  2. #42
    Dec 2016
    Raleigh, NC
    127
    Capture.PNG I was trying to use the setup he uses but it doesn't work with the new version of the vcm scanner. I'm logging MAF and the MAF sensor which shows the frequency. I'm also logging all my fuel trims and the EQ ratio commanded.
  3. #43
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Take out whatever that is in the filter function section
    If it still doesn't work then post a log and your layout and I'll figure it out real quick
  4. #44
    Dec 2016
    Raleigh, NC
    127
    My layout.Layout.xml I can't go out and test to see if removing that helped until around 3:30est. But there's my layout, if you find any problems or think I should scan for something else please let me know I'm open to anything.
  5. #45
    Dec 2016
    Raleigh, NC
    127
    So I need to log MAF lb/min by my MAF frequency and I'll change the tune to what I get in the scanner?
  6. #46
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    no.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  7. #47
    Dec 2016
    Raleigh, NC
    127
    Any problems with the layout?
  8. #48
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    You still have random stuff in a few filters that at best won't do anything or at worst will make nothing ever show up
    Without a log that's about all I can tell
  9. #49
    Dec 2016
    Raleigh, NC
    127
    Capture2.PNG I have it set like this and with over a 1000 hits my data is still different from my MAF calibration table.
  10. #50
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    What you've got in there serves no purpose for tuning
  11. #51
    Dec 2016
    Raleigh, NC
    127
    What do I need to log to calibrate the MAF sensor for my cold air intake?
  12. #52
    Tuning Addict
    Jan 2015
    6,815
    Where parameter is > change to either air fuel error or fuel trim error > both will be under the maths or user defined section if you have your own
    You can even clone the graph for quick duplication and have one log trims, one log air fuel error or lambda error or whatever...
    Might also want to change cell hits required to something like 3 or 4 as well... It's also easier to kill the long terms in the tune or via scanner controls and tune off of short terms only until things are close - this way lt's are carrying over into PE and your PE corrections will be correct and not influenced...
    ~Greg Huggins~
  13. #53
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by johnny_boii View Post
    Fuel trims while in closed loop (there's a LTFT + STFT math parameter that I usually use)
    EQ Ratio error or AFR ratio error in open loop/PE (have to have a wideband for this though)
  14. #54
    Dec 2016
    Raleigh, NC
    127
    Capture3.PNG How does this look?
  15. #55
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    The problem is that is only going to do anything when throttle is over 90%, and when throttle is that high it's unlikely fuel trims will be active anyways (because it will be in PE mode).. so doubt it will be of much use
    Get rid of the filter and use fuel trims everywhere you aren't in PE IMO. Once in PE you need a wideband.
    It's not unusual to set filters so data is only taken from areas where you're in certain fuel trim cells or throttle is between two values or engine coolant temp is high enough, etc. but I don't think what's in there now will help
