Results 1 to 5 of 5
Thread: Fan Settings
    Nov 2004
    Louisville KY
    101
    Fan Settings
    With warmer weather around the corner (finally), I was going to change the fan settings to the following:
    Edit->System->General
    Fan type: 2 fans
    Current parameters:
    Fan 1
    On: 226
    Off: 219
    Fan 2
    On:234
    Off: 227
    Min: 30 mph
    Max: 35
    Change to:
    Fan 1
    On: 196
    Off: 188
    Fan 2
    On: 210
    Off: 202
    Leave the mph as it is.
    Any suggestions/comments? Any other changes I should make? Oh yeah, the thermostat is stock temp 180*.
    1998 Z28 Red/Gray HT, A4, 3.23
    |Pacesetter, Hooker ORYP, Aerochamber|TSP Cam, PRC dual valve spring kit, LS2 timing chain|LS6 oil pump,|SLP Air Lid, P&P TB, FRA, TBB|Fuddle 3400 2.1, B&M cooler|GM iridium plugs, Taylor 8 mm|AMW catch can|J&M PHB & LCA's|HPTuners 2.1|HP House & Dyno Shop
    Oct 2004
    Huntingtown, MD
    200
    Re: Fan Settings
    My 180 degree thermostat keeps the engine at 190. I don't want my fans running while I'm cruising on the highway, so my low speed is set to 193/199 and high is 200/206. Has worked great for me.
    Phil K.
    02 Camaro SS 5.7L LS1
    01 Silverado 1500HD 6.0L LQ4 4L80E 78/75 turbo with Flex Fuel
    Nov 2002
    Central Florida
    2,503
    Re: Fan Settings
    I have a "160" thermostat and have things set even lower.
    Similarly, I wanted the fans to run only when they have to.
    I found my low-throttle highway ECT was about 175F. So I
    put FAN1 177/176 and FAN2 179/178. I don't care about
    hearing the fans. I want a stable ECT so I can tune it right
    up against the ping limit.
    Thought many times about making the fans thermostatic
    controlled so as to keep the tank temp down at 160 or so.
    That ought to make for a nice tight temperatore control in
    the water jacket. But never have gotten around to that.
    Nov 2004
    Louisville KY
    101
    Re: Fan Settings
    Thanks for the replies. First time flashing PCM so I wanted to make a "simple" change to see if everything goes ok.
    Thanks again.
    Oct 2004
    Huntingtown, MD
    200
    Re: Fan Settings
    Good idea on simple changes. Fans are what I attacked first as well.
    Phil K.
