Hi guys how can I turn the SRS light off.
after changing the seats the SRS out not turnoff.
I did the battery disconnect and it did not work
Holden V8 A4, Comp Cam, Headrs, ASP pullys, K&N filter, HPTuner.&&
Did you change the seat belts as well , or perhaps disconect the wires that went to the seatbelts ?
Air Bag’ and ‘Seat Belt’ pretensioners. The SRS icon is displayed when the ignition is first turned on to indicate that it is working. If the icon ‘SRS Airbag Fault’ graphic illuminates while driving it indicates that there may be a malfunction.
I was talking to someone today who installs car alarms and he told me of someone that was killed when they were checking the wiring under the dash and they caused the airbag to deploy . He said their head was in the way and it broke their neck .
