My car currently has a fairly common error with the traction system where it throws 3 codes on the driver info center at start and shutdown (service active handling, service ABS, service Ttraction system) related to diagnostic code C1214. As you could imagine, this gets pretty annoying.
Until I can get the actual issue resolved, is there a way to disable the lights on the dash and driver info center from coming on?
*Note, code C1214 is NOT in the DTC disable drop-down box*
Also, I have a poor understanding of the difference between the SES and MIL disable? From a functional standpoint, what will disabling each of these do for me? I've read the help file cover to cover.
Thanks in advance!
