Results 1 to 4 of 4
Thread: Some Questions regarding Diag,Immo
    Potential Tuner MinusG40's Avatar
    Mar 2008
    UK
    5
    Hi,
    sorry for my English (it isn't my mother tongue) . I'm here because i have a lot of question before to buy this product, i will speak before of my project, i just want to swap a Cobalt SS engine with the PCM in a Lotus Elise S1.
    I want to know if is possible to desactive all diagnostics like CAN network,AC diagnostic ? it's possible to erase immobilizer strategy (and this feature working without need of key etc ...)? Can we have only one oxygen sensor rather than the two?
    and my last question (maybe i will have some more questions later), you use a OBD2 interface but in my case i will have not this interface, i need just to take the CAN from the PC or do need power supply etc .. ?
    Best Regards
    Nicolas
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    You'll be able to delete any dtc's thrown by the pcm as well as disable vats on the pcm side of things.
    Mar 2008
    UK
    5
    Hi Bill,
    thank for your answer but you answer partially i want to disable diagnostic not clear DTC that mean can i erase diag made for CAN node presence or a remove sensor ?
    Because this PCM will feel alone
    Nicolas
    HP Tuners Support
    (foff667)
    28,268
    You can disable the dtc's & clear the DTC's.
