how do u turn off an egr for a 3800 series 2 v6? it is in a 2002 camaro.
Go to Engine > General > EGR > Min IAT & set to 284*F.
Also set all EGR codes to no error reported.
Russ Kemp
Whats the benefit of turning off the EGR?
Disabling EGR allows more air since the exhaust gasses reintroduced by the EGR's operation usually displace the oxygen allowed. This means more fresh air and less carbon buildup in your intake.
99GTP: Flowmasters, ZZP Power log & Ported rear, 9.5:1, Bored over .010, removed balance shaft, Dbl roller chain, Intense S1X, custom ported heads, 45#inj., 105lb springs, 1.7 rockers, A103's, 180-stat, Gen V swap, 97 Cadillac TB & Custom machined alum. spacer, 95 GTP Hood louvers
97GTP: Stock engine, 95 GTP Hood louvers
You will probably also see a slight decrease in fuel efficiency.
2005 Grand Prix GTP
My CarDomain Page
^^ x2. About 1-2mpg lost. I disabled the EGR so that the carbon would not clog up the intercooler.
2000 Regal GS | Twin-Charged T72 | HPT Pro + PLX Wideband | 12.55 @ 110 on 15psi | Now running 20psi on E85!
1998 5.9L Durango | Powerdyne supercharger @6psi | Mesa Headers | Gibson Cat-back | 1.7 RR's | Tuned PCM | Ported Heads | Custom TB & Intake | Custom fuel rails | Rebuild coming soon...
You will also see part throttle KR during highway speeds.
No, once the EGR is disabled, the EGR spark table isn't used. But if you just unplugged the EGR, then there will be part throttle KR.Originally Posted by bigbrian442
Just like a carburetor vehicle when the EGR vacuum hose was capped off, or the EGR passage was blocked with carbon.
Russ Kemp
Do the V6's have a EGR spark table? I know it's not mapped...Originally Posted by Russ K
2005 Grand Prix GTP
My CarDomain Page
I see no EGR spark table in my 98 V6 F body tune. Is it there and just not shown? I also don't see a way to disable the EGR, other then deleting the DTC's for it.
This is how to disable the EGR. And the EGR spark table is not included on the V6 car's.
Russ Kemp
With the absence of the EGR spark table on the V6 cars, Will disabling the EGR cause part throttle KR, with out tuning for it?
Read post #8Originally Posted by bigbrian442
Russ Kemp
