Results 1 to 3 of 3
Thread: rtt bug fixed yet?
    rtt bug fixed yet?
    has this been fixed yet? i'm using 2.2.0.0 and still have the issue it seems.
    HPT has identified this as a slight flaw in their software.
    From HPT....
    We have a small bug in the scanner. You will need to change your cylinder volume in the editor to 0.71249 for a 5.7L
    The scanner defaults to 5.7L, and that volume number is used to calculate the % for the VE table. You can change the value back to the correct cylinder volume when you are done with RTT. The cylinder volume is only used on the cranking VE table, so it will not affect your main VE tuning.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Please send your .hpt file & a vcm suite infolog while connected to the vehicle in question and I'll have our engineers look at it.
    Should've been fixed in 2.1.18 according to the help file timeline and haven't heard anything otherwise since then
    Sep 2002
    Chicago, IL
    6,395
    Its fixed.. but you do have to re-apply the enhancement to your base file then re-uploading using write entire using a 2.1.18 or newer vcm suite.
    We got this guy Not Sure, ...
