I have done a few hours of Maf tuning and have been recently been working on PW. Yesterday after a few logs and small corrections in pw, in the middle of the log(at least 20 min into the log) I started going really lean (18.xx). Since then I have cleaned the maf, recalibrated the AFR sensor, tried multiple tunes w/ different maf and pw values and I still can't get this thing to settle down. To compare, before this happened I stayed in between 14.5 and 15.2 at idle, now I'm in the 12.xx's and sometimes 16.xx's. Also, for some reason I command values other than what I should be commanding. Sometimes I will command 14.1 and even as low as 10.2! My stoich is set at 14.7 and my pe at 11.7. I've never seen it do this before, it doesn't make sense.
