Results 1 to 11 of 11
Thread: fan on/off settings for 160?
    Tuner in Training BEEDEEBEE's Avatar
    Feb 2008
    Regina,SK, Canada
    21
    What should I put for the Fan on/off settings for a 160 thermostat? I was thinking 165/162 for fan 1 and 180ish for fan 2.
    Also, should I enable the climate control override?
    Thanks,
    98GTP - XP cam, P&P heads, GenV, 2.8/3.4mps, ZZP S3 I/C, dynotech tranny, FWI, TOG Xtreme Headers, 8.5:1 diamond pistons, LS1 TB and MAF, Si Valves, Comp lifters, ZZP base tune, 42#inj, machined intake, oversize rad, 3"exhaust w/no cat or res, Walbro 340,
    Oct 2007
    Lawrenceville, Ga
    327
    Not sure what this would be in *F, but when I was running a 160* stat I had Fan 1 set to come on at 79* and turn off at 75*. Fan 2 turned on at 85* and off at 78*.
    -Eddie
    1998 GTP - 3.4 [3.2] [3.0] MPS - custom CAI - F.1 Ram Air hood - XP Cam - Ported Heads - 1.84/1.60 Si valves - 1.6 HS Roller Rockers - 72mm Ported TB - LQ4 MAF - 42.5# Lucas Injectors - Pacesetters
    1/4 PB - 13.025 @ 106.81 MPH w/ 2.069 60'
    2021 Chevrolet Colorado 2.8 Baby Duramax
    Feb 2006
    Canada
    1,958
    Fan #1 on temp=185*
    Fan #1 off temp=174*
    Fan #2 on temp=187*
    Fan #2 off temp=183*
    Keep Climate Control Disable set to "Disabled"
    Also set your Ignition Off to 179* and whatever time you are comfortable with(mine is set to 120 sec's)
    You might also want to change the enable speeds as well. Mine are now set to:
    Fan 1 Enable: 52mph
    Fan 1 Disable: 55mph
    Fan 2 Enable: 74mph
    Fan 2 Disable: 77mph
    Feb 2008
    Regina,SK, Canada
    21
    Will it have trouble keeping temp at 160 with the fans coming on that late?
    Feb 2006
    Canada
    1,958
    Haven't had to touch those settings for two years now. Temp stays a lot more constant. With the factory one the coolant temp was all over the place.
    Feb 2008
    Regina,SK, Canada
    21
    Alright, I'll try those settings. Thanks for the help.
    Mar 2008
    Paris, France
    435
    What are the settings for a 180 ?
    Aug 2007
    New Jersey
    28
    Personally, I'd just subtract the difference between the thermostats, and then lower the on/off settings by that much (180 would be -15; 160 would be -35). Then, I'd just set the key off one at the thermostat temperature rating.
    The thermostat isn't fully open at 160; it begins to open at that point. Flipping the fans once it cracks is kind of pointless, in my opinion.
    Oct 2007
    Lawrenceville, Ga
    327
    180 Fan Settings
    Heres what I'm using with my 180* stat - works good.
    -Eddie
    Mar 2008
    Paris, France
    435
    Quote Originally Posted by Eddie-98GTP
    thanx! I've just try it, it works perfectly !
    Advanced Tuner xonelith's Avatar
    Oct 2004
    Whitby, Ontario, CANADA
    408
    I think MMGT1's are for a 180 too. Try either Eddie's or MMGT1's for a 180. Take off 20* for a 160 I guess
    -xon
    All Motor 2001 GA GT1
