Results 1 to 11 of 11
Thread: What would cause the Inj. Pulse Width to drop to 0.6 under load?
    Apr 2007
    South Gate, CA
    28
    This is a somewhat follow up post to my first post. My previous post was too vague, so here is a more direct way of asking what I need answered.
    I have a 99 Z28, ATI SC, 38# inj., with an erradict Injector Flow Rate issue. The Injector Flow Rate will fall to 0.6 every 7-10 seconds.
    The sample scanner file is performed at light load. If no load is placed on the vehicle it can not overcome the surge and turn off.
    I have tried a stock file, a stock file with new injector flow rate to accomodate the 38# injectors, OL, SD, disconnected MAF, checked for misfire, verified fuel pressure by hooking up a gauge.
    Can anyone give me a clue as to what would cause the injector pulse width to drop and come back up every 7-10 secs.
    Joe A
    [email protected]
    2004 STS TT LS1 Corvette; 2007 Z51 LS2 Corvette; 2004 STS Turbocharged Chevrolet Tahoe
    Tuning Addict WS6FirebirdTA00's Avatar
    Jan 2005
    Concord, NC
    8,093
    are you on a stock OS or a 2/3 bar?
    looks like you have an issue with the 5v reference circuit, that can be causing some issues there.
    Sulski Performance Tuning
    Apr 2007
    South Gate, CA
    28
    Quote Originally Posted by WS6FirebirdTA00
    This is a stock OS. The 5v Reference circuit is one of the DTC's. My understanding about that is that ECU will send a 5v reference to each sensor; but I thought that was done just once or only at startup.
    How can I isolate the problem and fix it?
    Joe A
    [email protected]
    Jan 2005
    Concord, NC
    8,093
    The is what gives the signal to the sensors (like the TPS, could possibly be injectors but I am not sure on that).
    I think this is built in to the computer, might want to swap computers with a buddy to see if it goes away.
    Apr 2007
    South Gate, CA
    28
    Thanks WS6FirebirdT00; the injectors are new and where recently installed with the ATI kit. I think the strangest part for me is that both banks drop at the exact same time. How often in your experience does an ECU go bad?
    I found this about the 5v reference:
    http://extreme-check-engine-light-co...ur-gm-engines/
    Joe A
    [email protected]
    Jan 2005
    Concord, NC
    8,093
    it's not typical, but it happens. I know someone else had a similar issue with that recently, but I need to remember what the fix was.
    Apr 2007
    South Gate, CA
    28
    Really!? How long ago? Was it on a Camaro as well? We are thinking it just might be a bad ground. So we are in the process of double checking all ground connections.
    Joe A
    [email protected]
    Apr 2007
    South Gate, CA
    28
    Solved!!
    Thanks to EC_Tune and suggesting to turn off the VATS the strange behavior has stopped.
    Thanks Doug!
    Now the question becomes how would you reconfigure the VATS to properly function?
    Joe A
    [email protected]
    Jan 2005
    Concord, NC
    8,093
    hmm, weird.
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    If it's a key/lock issue you may have to replace the key/lock in the car.
    If it's a BCM issue then it may requre a new BCM (not cheap).
    Always Support Our Troops!
    I have got the same problem , VATS is off. but I noticed Idle Adapt (STIT) does not go to zero when revving the engine . I am guessing a wiring problem.
