lost all my logs and my configs?? Its a good thing I saved them to my home computer. Good luck everyone.
Did you look in your my documents folder & program files folder? They should still be in one of the two as I didn't loose any of mine in any of the tests we ran.
Yeah I looked, but will look again and thanks for the quick response.
Nope not in there either, its ok I have them saved.
Another quick way would be to go to Start-Search-All files & folders and in the all or part of the file name section type .hpt or .hpl & it will bring up where all the files went to, I would be curious as to where they went.
ok let me do some digging ahha
found the scans in the recent files.
can't find the config files anywhere ahha
check under my documents-VCM Scanner.
there not there either, I just rewrote them its all good, I did do a search under .cfg and they showed up there, but since I rewrote them it goes to the new config.
Are there any issues with the gauges on the Scanner? I tried to set it up with a background picture, which will not appear. And in the Configure window, clicking that floppy disk gives me a "Not Available" box. Don't know what "Load Gauge Display Settings" means, but I would think it would save changes and also do the same action as the "Commit Changes" button. I haven't tried scanning, but that was the only cosmetic thing I really noticed, which isn't a huge deal anyways. I got my gauges all setup in regards to colors and alike.
NotedOriginally Posted by Screwball216
