Results 1 to 7 of 7
Thread: trans "chirps" on shifts
    Tuner in Training 01badbird's Avatar
    Jul 2005
    Ortonville,Mi
    12
    good power but when time to shift trans. chirps not tires, disabled trq. mngt.and did basic tune trans has been rebuilt and have new converter tci 3000 stall .trans feels better except for shift . maybe fuel cut off ? help!
    2001 T/A LS1 A4-airlid,k&n filter,descreened maf,sm. bellow,loudmouth exh.,TCI torq. conv. (streetfighter),trans. rebuilt for race,trans cooler w/fan
    Jul 2005
    Ortonville,Mi
    12
    Re: trans "chirps" on shifts
    also could this be a engine mngnt. seems like same prob. ihad with 94 on perf. mode. its like a slip or something taking away from trans @shift points. can i run scan or trans. diag. ?
    Jul 2004
    1,579
    Yes, the PCM has an Engine TM and Trans TM. I would highly advise against deleting the Trans TM, I would just reduce it. As for Engine TM ... go ahead and kill it.
    Jul 2005
    Ortonville,Mi
    12
    thanks ,appreciate the input just a newbie but got to start somewhere or you'll just sit and watch everyone go by
    Jul 2005
    Ortonville,Mi
    12
    any help how-to delete thanks!
    Nov 2002
    Central Florida
    2,503
    I think you should log your trans shifting related params
    and see what's up. Particularly your input and output
    shaft RPM. Look at the ratio in Excel. What you want to
    see is a crisp step from gear to gear, with the shaft ratio
    in/out moving directly to the nominal gear ratio of the box
    within a couple of "ticks" (tenths of a second). The input
    shaft RPM should reduce monotonically. What you don't
    want to see is "flare" (input RPM goes up sharply and
    then down) or an extended time for the shift to complete.
    If you hear it "hooting" this may be slip in the various
    frictions. That would be bad. The higher-stall/STR
    converter makes life more difficult for the trans as it
    multiplies the torque just as you're trying to shift. So
    you may have to up shift pressures and lower the
    adaptation time settings (try 0.15) to stiffen it up.
    Torque management will roll back the delivered torque
    long enough for the clutches to grab. The new converter
    unfortunately fools the delivered torque - trans calcs
    I believe because the PCM "expects" the stock profile
    of slip vs torque@RPM, and when it sees 2000RPM
    of shaft slip it (I believe) figures in a -lot- of multiplication
    leading to higher torque reduction commanded.
    Try something like this. Look at your Engine > Spark Retard
    vs Torque Reduction table. Find the point where it commands
    a (say) 15 degree retard. On mine this is about 9% (9.3%
    is 16 degrees). Taking out 15 degrees would leave you with
    15 advance at WOT, which is a fair bit better than -10
    through the shifts.
    Now go to the trans torque reduction, Torque Reduction % vs
    Torque vs Gear. If you want to get 15 degrees of spark
    taken out and give the trans an easier time, rework the
    table so its max reduction is 9% (or whatever) and it slides
    on into it smoothly. The idea is to never command more
    reduction, than you like the spark pullout for. The stock
    table pulls out up to 37% torque and 32 degrees timing.
    Afterward log your Delivered Torque - Engine (which is a
    less-convoluted calculation) and see how much torque
    drop you get across a shift. Probably want to slide it
    back to 250lb-ft, because if you were to see the 2.2:1
    multiplication (insert your converter value here, this
    is for my TCI SF3000) you want to stay below the
    600lb-ft "rating" (less, lasts longer) for multiplied torque
    put to the input shaft. 250lb-ft will keep you moving
    forward but be a lot kinder than 350+ lb-ft, multiplied
    up by the converter being flash-resisted by the trans
    shift. Massage the reduction value up or down a hair
    until you get a torque cut that you like the feel of. Or
    are prepared to tolerate in the name of service life.
    Jul 2005
    Ortonville,Mi
    12
    THANKS JIMMYBLUE Seen your posts and looks like you've been doing your homework.I appreciate you taking the time to help I know its hard to figure out whats up not being at car but you might of sent me down the right path also it only does it WOT. THANKS AGAIN TRANS MAN!!!!!
