Results 1 to 8 of 8
Thread: Scanner problems please help
    Advanced Tuner dont_blink's Avatar
    Feb 2008
    Denver, CO
    466
    Scanner bugs out almost everytime
    Almost everytime I start up scanner and start to scan it will only grab half the parameters the first time. So I stop it and start a new scan and then usually one of the parameters is dead and reading a flat number. Then I have to stop and start it AGAIN before I can finally log everything. This gets REALLY annoying at the track when I'm about to make a pass. I have the new Beta version, but even the one before it did this also.
    Also, either I'm the greatest tuner to ever live or my knock sensor values aren't working. I swear I can run my normal 17psi, run the afr up to 13.0 on my wideband, advance timing to 30 degrees at WOT and still see no recorded knock. Any ideas? It's a 2004 Ion Redline.
    RSG Offroad
    Jeeps. Jeeps. And more Jeeps. Oh and Jeeps too.
    Jul 2007
    218
    i'm haveing the same problem, are you using vista or xp??
    the scanner was fine untill the new update here.
    Feb 2008
    Denver, CO
    466
    I'm using XP.
    RSG Offroad
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    Me too, happens on my own gmc truck... Net 2.0 an Windows vista with latest HP Tuners
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    I can try and recreate it if you guys can tell me how many bytes you are logging so I can get an idea of some things to try.
    -Bill
    Jul 2007
    218
    I have the default settings and when I minimize the histogram display it puts the scanner at half the size, but as soon as I inlarge the histogram display the scanner operates in normal viewing, except for the lines dont match the fields there supposed to.
    Jul 2007
    218
    shows me with 259 frames is this what you need??
    HP Tuners Support
    (foff667)
    28,268
    Quote Originally Posted by kevmar
    I really do not understand what you are trying to say
    A screenshot might help.
