Results 1 to 8 of 8
Thread: maf/2bar question
    Jul 2005
    arkansas
    530
    maf/2bar question
    i'm going to 2bar in my tahoe. its an 04 and in the tuning section it tells you not to disconnect the maf because it will revert the trans to full shift pressure. when you go to 2bar OS does it do away with this? i would like to ditch the maf if its not being used but not if its going to go to full line pressure.
    '04 Tahoe AWD, trickperformance turbo kit, TC78 turbo, 4"magnaflow muffler, Circle D triple disc 3,000, FLT LVL 7 4L60E, L92, 227/235 111lsa.
    Old 5.3=12.33 @110mph
    http://www.streetfire.net/video/turb...mph_741849.htm
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,273
    Trans will revert to full line pressure on only a small handful of pcm's ie most 98-00 pcm's
    Jul 2005
    arkansas
    530
    so how do you know if it does it or not?
    HP Tuners Support
    (foff667)
    28,273
    Are you using a 98-00 pcm?
    Jul 2005
    arkansas
    530
    nope, 2004. i ask because i swapped mafs with a friend to trouble shoot my turbo. and he says his truck shifts way better than it use to. mine seems to not shift so good but it may be in my head. but he is loving his truck all over again. but if i have nothing to worry about then i plan to ditch it soon as my coblat maf gets here.
    HP Tuners Support
    (foff667)
    28,273
    04's don't default to max line pressure when the maf fails.
    Jul 2005
    arkansas
    530
    well, i ordered my 2bar sensor today. what all do i need to do when i go 2bar? besides of course the sensor and OS. i'll check out the help file when i get home. but thought i'd ask incase there is one of those " hey by the way make sure you......"
    Jun 2006
    Western Pa.
    331
    Just go through and do it as per the help file, that is what I did and it worked just fine.
    04 Sierra Denali,370,S485B, Built 4L80E, 3barOLSD, E85
