I posted this over on LS1tech, but I haven't gotten a response yet. So either I'm not asking the right questions, or all the smart guys aren't on that board today....
I finally got around to logging a WOT run after my Yank SS3200 install. I only picked up 2/10ths at the track, ALL in the 60', and I lost ~ 2mph. So I knew something was amiss. Anyway, what I found was this:
I have the car set to shift @ 6700, DFCO @ 6800, but the car never hits that target. It shifted at 6500 1-2, and at 6200 2-3. The 1-2 shift hit the MPH limit, so that most likely explains that (more later) but the 2-3 was 6mph under the shift point, so that one really puzzles me.
At 5600rpm in 1st, the MAF is pulling 35.2 lb & the dyn cyl air is .7 g/cyl. Then both start to fall off up to 6450rpm where everything flattens out until it hits 37mph & shifts (at 6500). At that point the MAF is around 38lb but the air dips down to ~.65 g/cyl. In 2nd when it shifts at 6200rpm, the MAF is at 36.4, the cyl air is .68, and the mph is 66.
I wound it out in 3rd & again about 6500 everything started to fall off.
EVERY table is set to make it shift @ 6700rpm, 37mph 1-2 (raising that) & 72mph 2-3. So waht gives? All I can think is that maybe I need to do the SD tuning & re-scale my MAF tables accordingly. (actually, a friend - Racehead - thought that might be my problem). I have never messed with that stuff.
Any ideas? ??? I need some help figuring this out if I'm going to run an 11 sec cam-only 1/4 mile. (I'm at 12.29 now)
Thanks!
Mark
