When I got my car back from Dynotech they never really touched the WOT speed shifts for the 3.29 gear ratio. So pretty much I have the stock 2.93 speed shifts in my PCM. I wanted to know what people put into those tables for 3.29 gear ratios? I just notice that my car will only downshift one gear at WOT and sometimes doesn't even downshift which makes the car feel like a dog if I am in 3rd gear. Also ever since I had the northstar installed onto the car the shifts at WOT just don't feel anywhere quick/tight like they used too. I have a feeling I need to increase line pressure but I don't know how high and at what part of the charts I do that. I did increase the line pressure over stock and the upper parts of the chart to 96 psi however it feels about the same. But this is up in the 500lbs+ range. should I raise the lower parts of the charts to 96 psi?
I am going to the track soon and I just want to make sure my transmission settings are the best they can be. Also what should I have my Desired shift times at in performance mode for my transmission with the mild shift kit installed from Dynotech.
