I've got a weird situation where I need to quickly change a cells reference.
For instance.. I have three columns
MAP, RPM, G-Meter
But in another situation I have
MAP, RPM, Brake temp, G-Meter, Trans Temp
What i want to do is have a cell that says go to C1 for G-meter in the case I get the first set of data and D1 for G-meter if I get the second case of data by changing one cell that I'm going to use as a constant. For instance at the top of the page I'll have "data set in column, D" Is this possible?
