Page 1 of 3 123 LastLast
Results 1 to 20 of 52
Thread: Quick question about cruising speed timing for L67
    May 2008
    Royal Oak, MI
    5
    I just have a quick question. Is ok to be running between 38-40* of timing when I'm cruising at 70-75mph?
    I have no KR and my AFR's are 14.3-14.5. It seems to me like it's ok, but I just want some more experienced opinions.
    1988 Fiero GT w/ l67 and 4T65EHD swap
    256rwhp/319rwft/lbs and [email protected] in the 1/4
    Oct 2007
    Lawrenceville, Ga
    327
    I run upwards around 48* during light throttle cruise.
    -Eddie
    1998 GTP - 3.4 [3.2] [3.0] MPS - custom CAI - F.1 Ram Air hood - XP Cam - Ported Heads - 1.84/1.60 Si valves - 1.6 HS Roller Rockers - 72mm Ported TB - LQ4 MAF - 42.5# Lucas Injectors - Pacesetters
    1/4 PB - 13.025 @ 106.81 MPH w/ 2.069 60'
    2021 Chevrolet Colorado 2.8 Baby Duramax
    Tuner bigbrian442's Avatar
    Sep 2007
    Pasadena, Maryland
    174
    Are you under boost while cruising?? I run 40*+ while cruising but I'm NA.
    Oct 2007
    Lawrenceville, Ga
    327
    No, no boost while cruising. There isn't much difference between between SC and NA during cruise conditions.
    -Eddie
    Sep 2007
    Pasadena, Maryland
    174
    Should be no problem running lots of timing during cruise then. I'm guessing a stock cam wouldn't like 48* timing. Cylinder pressures should be higher in the cruise range with a stock Vs after market cam.
    May 2008
    Royal Oak, MI
    5
    Thanks for the replies! I tought I was ok but I just wanted to make sure. I really only know about tuning in PE mode for the 1/4 mile. I have recently started working on my regular driving tuning and I just wanted some opinions to make sure I was going in the right direction.
    I guess I'll bump the timing up a bit more.
    eddie, do you get good gas mileage? i recently cranked my timing up to the low 40's range while cruising because i had disgusting gas mileage, and only 22-23* light throttle cruising, 40+ while coasting. i havn't had a chance to see what my mileage is, but i hope it gets better.
    anyone here run e85? Im curious how much that would effect cruising timing, being 105 octane. i may get mine up to 48 as well, seeing as how you can pull it off with 87 octane gas...and im assuming a 3.4 pulley?
    2008 G8 GT / TVS1900 /2.9 pulley / LS9 Injectors/ LS9 Cam / Catback / Intake
    Oct 2007
    Lawrenceville, Ga
    327
    Yep, 3.4 pulley but I've started running 89 octane (need to change sig.) since our drive time temps are over 95*F this time of year. I drive in a lot of stop and go traffic, so the engine gets a good bit warmer then if I were cruising more.
    Anyway, I started with 2005 GTP timing tables (High and Low Octane Spark Advance and Max Torque Timing tables) and tweaked from there.
    Not sure about the E85. I know it has higher octane, but it also burns cooler if I'm not mistaken. This should help you run higher timing, just don't go too high. The trouble I see with using E85 is the AFR and price difference. I've thought about trying it out since a station down the street from me carries it, but the price is about $3.50 compared to $3.90 for 87 octane. That's only about 11% difference in price, and from what I've heard the MPG difference is closer to 18%. How is the E85 working for you? How is your fuel economy compared to gasoline?
    -Eddie
    ill have to check out the 2005 tables to see what they look like
    where i live, the price difference is $3.25 to $3.94...I live in minnesota, and there are more E85 stations here then anywhere else, probably why the bigger difference.
    my mileage has been pretty bad for a while, i dropped from 17 average to 13.... i should be able to get it back up to 16-17 from what other people with 3800's are saying while on e85. ive gotten bad mpg for a long time, and i hope it was all related to low timing during cruise. i believe the last time i had good mileage was when i had a dhp 1.0, but its been so long.
    i mostly do it for a performance / safe for the engine standpoint. since i run a 9.4 cr block, i wouldn't be able to run a 2.8/2.9 pulley without it. i could probably run smaller, but i dont have any desire to try.
    Aug 2005
    Midlothian, VA
    205
    Quote Originally Posted by Eddie-98GTP
    Attached are my stock timing tables. What do you think I could bump my timing up to? I see knock in the higher RPM's, but nothing during cruising. Would it be safe to increase timing by 5 degrees at a time (in cruising)? What range is cruising? TIA!
    Mitchell
    '04 Supercharged MC SS
    MOD LIST
    Custom PCM, Ram Air Hood w/ Air box, Intense MPS w/3.6", R/T DP with Ubend delete & HF CAT, LC-1 WB, GMPP Cat Back, Jacobs wires, 180 T-stat, & an Optima Red Top
    Oct 2007
    Lawrenceville, Ga
    327
    starks: What did you have to do in order to run E85? Did you have to replace any injector or fuel rail o-rings? I should be able to run it as far as injectors size goes, but I've heard storys about the E85 eating stock o-rings. I'm not sure about the year, but something else I've heard is that E85 compatible o-rings and fuel lines have been used in just about all cars from 1997 to present. Not sure what is true though...
    mtcrusan: I would raise the timing in 1-2* increments in the 1400 to 2800 RPM range and .12 to about .44 g/cyl range for cruise. 5* increments are a lot, I would not try that although you may enmd up being able to raise your cruise timing as much as 10*. Do not try to go over 45* or so, there is no gain after that.
    -Eddie
    Aug 2005
    Midlothian, VA
    205
    Thanks Eddie. I will try it out.
    Mitchell
    MOD LIST
    Eddie, when i put the siemen #60's in, i also put viton o-rings on them. i believe they were stock on 3100 cars as when i went to the parts store to get them, he gave me o-rings for a 3100. not sure on the year. you can they are viton's because they are purplish instead of the black rubber ones. i also use a flex fuel filter. its made for a tahoe 5.3 flex fuel. it fits perfect, but installs with the flow arrow facing opposite of the actual flow. stock rubber o-rings will swell, then leak eventually
    with the 60lb injectors my IPW's are in the 16-17 range when its about 70*, so i still have some headroom (thats with a 2.9 pulley). e85 would let your car run a 2.8 probably, but i dont know if your injectors would be good down to a 2.8" pulley...with a fuel pump re-wire, that would be close. right now its my fuel pump thats pretty much maxed, injectors have more room.
    still crappy gas mileage....about 41* cruising timing.
    im going to switch from e85 2.9 pulley to 92 octane 3.1 pulley.... see what happens.
    i even put a new motor in (spun 2 bearings) and went with a 9.4 cr block, and added a full size IC as well. no change in mileage.
    eddie, would it be possible to take a look at your tune?
    Oct 2007
    Lawrenceville, Ga
    327
    Sure, I'll post it tonight - if I remember
    -Eddie
    Oct 2007
    Lawrenceville, Ga
    327
    Here is a list of the tables that have been changed from stock.
    The AE tables are mostly 2005 GTP, everything else is custom
    The Operating System ID is 9352809 and contains 440 tables.
    Accessories
    Fan 1 Coolant Temp
    Fan 1 Keyoff Coolant
    Fan 1 Keyoff Time
    Fan 2 Coolant Temp
    IAC Desired Idle RPM
    A/C Disable RPM
    A/C Disable/Re-enable TPS
    A/C RPM Re-Enable
    Immediate A/C RPM Disable
    Alternator RPM Cutout
    EGR Air Temp Disable
    EGR Disable TPS Threshold
    EGR Enable TPS Threshold
    Fuel Related
    Base Fueling
    Cat Protection Coolant
    Closed Loop Fuel Enable RPM
    Engine Runtime for Closed Loop
    O2 Sensor Rich/Lean Threshold
    Open Loop Base AF by Coolant Temp
    Possible Closed Loop Fuel Disable RPM
    PE
    Base PE A/F
    PE A/F vs TPS
    PE Enable TPS - Hot
    PE RPM vs Time A/F
    MAP
    Default Max MAP
    MAF
    MAF Airflow Table
    Volumetric Efficiency
    Fuel Injector
    Injector Flow Rate
    Injector Skew Percent
    Acceleration Enrichment
    AE Modifier vs Speed
    AE Modifier vs. Baro
    AE TPS Re-allow
    AE vs TPS Max Delta
    Disable TPS Closing Delta
    Enable TPS Delta vs. ECT
    TPS Filter Coefficient
    Deceleration Enleanment
    Decel Enlean vs TPS
    Spark tables
    Base Timing
    AFR Spark
    Air Temp Spark
    Closed Loop Idle Spark Correction
    High Octane Spark
    TCC Spark Advance Correction
    Knock Sensor
    Knock Retard Recovery Rate
    Speed/Timing Limiter
    High MPH Limit
    Transmission Changes
    Shift Point - Performance
    1st to 2nd Performance Shift
    1st to 2nd Performance Shift RPM
    1st to 2nd Performance WOT
    2nd to 1st Performance Shift Line
    2nd to 1st Performance WOT Shift
    2nd to 3rd Performance Shift Line
    2nd to 3rd Performance Shift RPM
    2nd to 3rd Performance WOT Shift
    3rd to 2nd Performance Shift Line
    3rd to 2nd Performance WOT Shift
    3rd to 4th Performance Shift Line
    3rd to 4th Performance Shift RPM
    3rd to 4th Performance WOT Shift
    4th to 3rd Performance
    4th to 3rd Performance Shift Line
    Shift Time
    1st to 2nd Normal Shift Time
    1st to 2nd Performance Shift Time
    2nd to 3rd Normal Shift Time
    2nd to 3rd Performance Shift Time
    3rd to 4th Normal Shift Time
    3rd to 4th Performance Shift Time
    Shift Pressure
    Shift Pressure 2nd Performance
    Shift Pressure 3rd Performance
    Shift Pressure 4th Performance
    TCC
    TCC DC Min - Line Pressure vs Trans Temp
    TCC Pressure Apply Rate
    Supercharger tables
    Boost Control
    Boost Control - Timer Max
    Boost Ramp Rate
    Catalyst Protection Boost Shutoff
    Decel Boost Control by Throttle
    Excess MPH Enable by MPH
    Torque Managment
    Fuel
    Disable All Injectors High MPH
    High RPM Fuel Cutoff
    Torque Abuse A/F
    Torque Abuse Differential Score A/F
    Torque Abuse Drive Injector Disable
    Torque Differential Score Injector Disable
    Traction Control # of Injectors Disabled vs TC Mode
    Traction Control Desired A/F
    Spark
    Torque Abuse Spark
    Transmission
    Brake Torque Limit
    Max Turbine Torque TCC Unlocked
    Torque Reduction 1st to 2nd Performance Upshift
    Torque Reduction 2nd to 1st Downshift
    Torque Reduction 2nd to 3rd Performance Upshift
    -Eddie
    I run E85, however i didn't know changing the cruising advance would do anything.... Sound interesting... someone must enlighten me more, there isn't enough info here for me to change my timing tables while cruising... is there a benefit?
    Oct 2007
    Lawrenceville, Ga
    327
    There is a huge benefit. Better performance and better fuel economy for example.
    Have you changed your timing tables at all?
    -Eddie
    i have changed all my wot stuff, i am currently running 23-26* of timing at wot on a 3.2 pulley and no intercooler on e85. I have not changed just regular driving lol, this is the first time i've heard of it. If there are gains then i'm all over it. What would you suggest i start off with? i have stock stuff, like idle is 25, and i see 39's in some places , but mostly low 30's. this is good to hear...
    Oct 2007
    Lawrenceville, Ga
    327
    Honestly I'm not sure how much to tell you to add with E85. I know with gasoline, running 26* at WOT is not real good. Anything over about 21-22* offers no gains for for those that can even get that high.
    -Eddie
