Results 1 to 7 of 7
Thread: ltft stft dont read at all
    May 2008
    3
    why cant i get the ltft and stft to read trying to ve tune
    car info
    2000 camaro a4 lid, gears, 3500stall lv2 4l60e and P&P tb
    Open up Editor and go to Engine --> Fuel Control --> OL & CL
    Check the Closed Loop Enable ECT vs. IAT table to see if the values are anything other than 284.
    Also check that LTFT Enable option is set to Enable.
    Here is TXRED log from his car.
    May 2008
    3
    LTFT is Enable, IAT table values are 92 a cross the table
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    that's easy enough to see in the logs; B1S1 (front driver side O2) is dead/bad heater ckt.... surely it's set a DTC code and that is why it won't go into closed loop.
    Steve Williams
    TunedbyFrost.com
    May 2008
    3
    doh now i feel dumb thanks frost
    If you're near by 1320 Performance in South Texas, take it there. Im sure they will help you out.
